Bug Report: ALT+Space entries
MarkusJu
Post by MarkusJu » Jan 7th, ’19, 17:56
I have a few auto-complete entries here, which work ok, wenn you use them while normal typing and selecting the entry.
These entries don't work if i use the ALT+Space short cut (Quick find option under shortcuts).
It seems it is because these entries have a "space" in the string field, e.g. "Address Customer". If i rename the entry to "AdressCustomer", then it works.
Is it a bug or is this intended?
Post by Marko » Jan 7th, ’19, 19:03
Thanks, this is a bug and will be resolved in a new release. :oops:
