Chinese always has garbled characters.
In the substitute, Chinese always has garbled characters. Changing the font is also invalid.
For example, the original text is like this:侯希白赞道:“子陵猜得不错。 After closing the software and opening it again, the original text content becomes:侯希白赞[u��-�.��)
Thanks for reporting this, we will take a look.
This problem is not frequent, input Chinese after several times before use without any problems, but closed again after opening the software editor, will appear garbled.
yes, it looks like the text is saved and the substitution works correctly. In some cases it is just not loaded correctly into the field when edited. We'll test this further.
Could you check the new release 4.15 and let me know if the issue is resolved?
Very nice!!! I admire the developers for their timely updates. Chinese input, edit and output, no more scrambling!
Two more suggestions:
1.Text ExpanderWindows can't be maximized, and a lot of text editing is painful.More——》edit:Function is very weak, no search function. Reference software:Notepad2。
2.Text Expander the pop-up window can not be fixed on the editing software, so it is not convenient to choose. Reference software:PhraseExpress。
Does your forum not provide the function of uploading local pictures?
Thank you again for providing a powerful software.
Thanks for the suggestions.
1. Settings edit windows can be resized, simply drag the window borders and make it bigger. The full editor (More/Edit) is certainly not trying to compete with dedicated text editors like Notepad++ etc., although we may add some features in the future.
2. Not sure what you mean by "not fixed on the editing software"... Can you please be more specific?
3. To post a picture link, just use one of the services like https://imgur.com/upload
Can be placed at the top, floating on any software, the mouse or keyboard can be selected, very convenient.
