Shift - (letter)
bendonahower
Post by bendonahower » May 19th, ’13, 21:23
It's probably not so much of a bug as something to keep in mind that if you created a Shift - (letter) command that you're going to make using capital letters much more difficult!
Post by Marko » May 19th, ’13, 23:47
Hi Ben, you are right. You can choose whichever shortcut you like in FastKeys but you need to be careful not to disable some basic Windows functionality.
Few ideas:
- you can disable any key or a key combination by selecting it as a shortcut, selecting "Command" type and leaving command field empty. The good example would be a "hated" Capslock key.
- when choosing a shortcut, don't forget to try a little "..." button to select many more advanced key or mouse combinations. You can for example select Ctrl-LeftMouseButton as a shortcut for some activity.
thinman
Post by thinman » May 20th, ’13, 12:27
good hints! Many thanks!
