Disable passwords completion
devclined
Post by devclined » Nov 7th, ’18, 17:14
Any way to disable passwords copy in buffer and auto complete it / remebering it ?
Post by Marko » Nov 7th, ’18, 18:17
I'm not sure I understand the question. If you use Auto learning you can specify the strings not to be learned in Preferences/Auto learn.
devclined
Post by devclined » Nov 8th, ’18, 13:33
yes its auto learning from my softwares where i type passwords, but still if enter all my passwords in not secure way in to the fastkeys, its not a good step:)
or maybe the solution is to add a wildcats and type just a first 3 letters of the pass for example like PASSWORD would be a PAS* or *ORD and it will be ignored
Post by Marko » Nov 8th, ’18, 19:29
Don't learn strings - Comma delimited list of the strings which prevent learning if they appear within a word. The strings are not case-sensitive.
So, if you specify a string "pas", any word containing "pas" will not be learned.
devclined
Post by devclined » Nov 9th, ’18, 05:30
Gotcha, thanks ! :D
