do not paste text by space
jkeks
Post by jkeks » Sep 17th, ’18, 13:27
set textexpander only for space, but nothing happen when press space.
jkeks
Post by jkeks » Sep 17th, ’18, 13:39
how to trigger textExpander not immadiatley, only by press space
Post by Tom » Sep 17th, ’18, 16:51
That's the default. Check the "kind regards" example - type "kr" followed by Space to trigger "kind regards".
jkeks
Post by jkeks » Sep 18th, ’18, 05:57
no, it's not !
if I check trigger immediatley, it will appear when i press kr without SPACE.
But if unchecked immediatley they will not appear any way (only by Alt-Space menu)
Post by Tom » Sep 18th, ’18, 06:04
Could you try to reset the Preferences to defaults?
jkeks
Post by jkeks » Sep 18th, ’18, 14:52
Yes// it's worked ! :lol:
