Function request
When creating a text expander file, and doing a send command, there is the option to record a macro but only keystrokes. It'd be much better if the recorder keystrokes just got appended to whatever was already there in the send phrase window. Currently everything will be repolaced by keystrokes from the macro, if you could keep text and just turn on the record on and off to do actions without replacing the contents of the phrase file window it would be much more useful
Right-click on the command field and enable "Insert mode". This way, a new macro will be added at the caret position.
