Selection Table Bug?
phocide
Post by phocide » Jan 12th, ’23, 15:28
If you leave an empty cell in the "Selection Table" and try to return a column with this cell, the cell of the "Selections" column will be show.
It should be like this:
12.01.2023 - 12.01.2023
It turns out like this:
[date1] - [date2]12.01.2023 - 12.01.2023
Also, you can not put spaces before and after the value, for example after "from".
from 12.01.2023 to 12.01.2023
from12.01.2023 to 12.01.2023
The only solution to the problem is to edit the table file manually using a text editor.
Post by Marko » Jan 13th, ’23, 17:21
This is intentional. If the column value to blank, the selection value is used instead. Also the column content is trimmed. We can discuss if this design is good or not. :)
I'm not sure what you are trying to do with the dates though.
