The "a" key doesn't work
sz@elettrodomex.it
Post by sz@elettrodomex.it » Dec 9th, ’22, 16:30
Dear Sirs,
I installed your fast keys software on my virtual pc and after a few days of testing, the letter "a" on the keyboard stopped working. I had to uninstall the program to get it back to normal. The physical keyboard didn't work and neither did the virtual one. Only the ascii code alt+97
Looking forward to hearing from you
Best regards
Post by Marko » Dec 11th, ’22, 21:13
You have probably set one of the shortcuts in the program to be the "A" key. Open FastKeys, select Shortcuts module and check it out. Also check you shortcuts set in Preferences.
