For some sites when I Text Expand (TE) items into fields, the content is changed.
For example if the text in FK is:
https://www.linkedin.com/in/kalmdown
The result ends up:
https:??WWW>https://www.linkedin.com/in/LINKEDIN>COM>?IN?KALMDOWN
Anyone know why this happens and how to get around it?
See images below for FK settings and result in page.
https://drive.google.com/file/d/1p0C7Qs ... sp=sharing
https://drive.google.com/file/d/1p4vFjj ... sp=sharing
Really wish FK used newer furom software that lets you drag and drop images into the text. Makes issue and idea reporting much easier.
Pastes different characters then the raw text
Unfortunately I cannot reproduce this on our systems. Does this happen in any application or only in browser? Try restarting FastKeys to see if this helps.
