Alt+Tab issue
ilm
Post by ilm » Sep 20th, ’22, 22:40
I updated today, but after the update (already restarted the pc and the program), some things no longer works, specialy the Alt+(multiple)Tabs and a continuous ctrl+shift+[left or right] to select multiple words. It`s like there is a forced interruption in the system. If I stop or shutdown the program, everything works fine. If there is no solution, I`ll try to reinstall the software in hopes this problem goes away.
marcelolima
Post by marcelolima » Sep 21st, ’22, 15:48
I have the same problem.
I had noticed this problem using "Alt + Tab", but I didn't associate it with FastKeys because I formatted the computer. (So I thought it was some configuration I had to do in Windows).
But I just realized that "Alt + Tab" keys with FastKeys inactive work normally. However, with FastKeys active, this functionality is impaired.
Post by Marko » Sep 21st, ’22, 15:49
Thanks for reporting, this issue has already been resolved. Please download FastKeys again and reinstall.
marcelolima
Post by marcelolima » Sep 21st, ’22, 20:58
Thanks, Marko.
ilm
Post by ilm » Sep 21st, ’22, 21:53
I updated this morning, and since then, it is working. Thanks.
