I have installed version 5.9 and when it starts it gives me the error "Error at line 179. Line Text: MediaPlayPause:: Error: Invalid hotkey. The program will exit."
(I have understood that all the scripts are saved in a single file (.fdb), I have checked line 179, and close, but there are no errors.)
I have had to go back to version 5.8, because although I have deleted some disabled scripts (to rule out options, since some shared enabled keyboard shortcuts), it still gives me the same error. I think the "error" is that I have assigned a keyboard shortcut to the "play" key (switch between play and pause) of the multimedia keyboard, so that it starts a music player, when by default Windows already has a function assigned to that key. But so far it has always worked and I have not had any conflicts. (I'd rather go back to the previous version than lose that feature.)
Media shortcut in version 5.09
Thanks. The issue has been resolved, please download again and reinstall.
Problem solved! Now everything is fine. Thank you for your prompt response and solution.
(off Topic: I have read that you have added the possibility of starting the script "Startup script: https://fastkeysautomation.com/forum/vi ... ?f=3&t=552" when logging in. Where is the information for do it.)
You can set a script in Tools/Startup script.
Here you can set the AutoHotkey code to run at each FastKeys reload. You can also define A_Variables which can later be used in your phrases etc.
