Date Calculator
marcelolima
Post by marcelolima » Sep 1st, ’22, 11:35
Hello, Team.
I have a need for a script to add an amount of days to a date.
For example: I should select the date such as 09/01/2022 (mm/dd/yyyy) and enter the number of days I want to add (for example: 90) and FastKeys reports the result: 11/30/2022.
In the calculation system offered by FastKeys, the application don’t have the option for the result to be found in date format, such as MM/DD/YYYY or DD/MM/YYYY.
https://www.fastkeysautomation.com/docu ... ation.html
If it is not difficult to implement, my suggestion to the team is that the calculation system could result in a date, not only digits/numbers, such as currently.
* And if there's another easy way to do this, I'm sorry. I'm just a newbie. :oops:
Post by Marko » Sep 3rd, ’22, 10:50
You should use Date and Time macro instead. You can apply the maths and date formats as you wish.
marcelolima
Post by marcelolima » Sep 4th, ’22, 13:40
Thanks for your help, Marko.
I checked your orientation.
As I understand it works only with the current date.
Would it be possible to insert a past date and, from this date, select the "shift" field?
Thank you again.
Post by Marko » Sep 6th, ’22, 17:22
Ok, we will see if this could be implemented in one of the next versions.
marcelolima
Post by marcelolima » Sep 7th, ’22, 02:01
I would like to use it through FastKeys, but no need to waste energy in this case.
The functionality I mentioned can be used by the windows calculator itself.
https://support.microsoft.com/en-us/win ... 67004faa43
Thank you so much!
Post by Tom » Sep 9th, ’22, 08:54
You can use this script (Type: Command):
Gui, Font, s10, Segoe UI
Gui, Add, MonthCal, vSelectedDate
Gui, Add, Text,, Add days:
Gui, Add, Edit
Gui, Add, UpDown, vAddDays Range1-60
Gui, Add, Button, Default gSelectDate, Select
Gui, Show
SelectDate:
Gui, Submit
Date := SelectedDate
Date += %AddDays%, days
FormatTime, Date, %Date%, MM/dd/yyyy
SendInput, % Date
marcelolima
Post by marcelolima » Sep 11th, ’22, 12:14
Thanks, Tom!
Exactly what I needed.
Best regards,
Marcelo.
