Hi, I've been trying out FK to see how it would work for me and I'ev created several excel files with the most common snippets I use. However, nothing is visible when I choose the Excel file. By the way, all entries are in Cyrillic, if that matters.
https://1drv.ms/u/s!AmDWN6Fzquj0hehMMEc ... Q?e=8ULGhx
Can't import from Excel
Hi Eva and welcome to FastKeys forum. I suggest you send your Excel file to our support mail and we will check what might be the problem. Thanks.
Here is one of the files:https://1drv.ms/x/s!AmDWN6Fzquj0hehJJ-FTgeJUoW2vwA
Thanks. I see there is an issue with this file. We will analyze it and resolve the issue in the next update. Thanks for reporting.
