Hi Support team,
%Cursor% does not work if there is Note:: at beginning of the line and an input field further to the right.
Example: Note::Subject %Cursor% (%INPUT_time%)
It works in this example 1:
Note::Subject %Cursor% (manual input)
It works in this example 2:
Best regards,
u_v
%Cursor% in conflict with input field further to the right
This works for me. Please check the Preferences/Text Expander/Advanced - what is your "Use clipboard if text length exceeds" setting?
Hi Tom,
"Use clipboard if text length exceeds" is set to 1500.
Best regards
u_v
Best regards
u_v
As said it works for me. Try to reset your Preferences.
