BUG: Letter # or + not fully supported for substitute strings
u_v
Post by u_v » Apr 20th, ’22, 09:43
Hi support team,
I would like to begin the substitute string of Text Expander with the letter "#" or "+" to avoid confusion with normal text.
Unfortunately this does not work for nested entries such as %INSERT_#abc%.
Best regards
u_v
Post by Marko » Apr 20th, ’22, 20:30
Thanks, we'll check it out and see if this could be improved in one of the next releases.
