Library not available
u_v
Post by u_v » Apr 20th, ’22, 08:18
Hi support team,
After installation library icon is visible. If you try to customizing the menu library icon disappears:
[img]file:///M:/44/4448-FastKeys/40-02-Bug-Library-20220420/01.png[/img]
[img]file:///M:/44/4448-FastKeys/40-02-Bug-Library-20220420/02.png[/img]
Note: Unfortunately I can not upload pictures in the forum.
With kind regards
u_v
Post by Marko » Apr 20th, ’22, 20:29
There is a limitation on how many icons can be shown. Try to disable some other icons and Library icon will appear.
u_v
Post by u_v » Apr 21st, ’22, 16:47
