Need to disable Menu in some app
vnnguyentr
Post by vnnguyentr » Mar 31st, ’22, 02:31
I know that there is a feature to disable Shortcut in some applications we want to in Setting menu. But how about the Menu? Could you please update the next version with the feature to be able to disable Menu in the apps or windows those user specified.
Thanks and best regards,
Post by Marko » Apr 2nd, ’22, 18:58
Thanks for the suggestion. Why would that be useful? You can select a shortcut for each menu and open it when you like.
