textexpander / work without binding to keyboard layout
Krasnij
Post by Krasnij » Jan 30th, ’22, 15:13
Hello, please add in textexpander one very important option: "change, if typed in other keyboard layout". Regardless of the selected layout language, autocorrect will work. Now, if there are several languages, you need to write a separate rule for each one. Thank you.
Post by Marko » Jan 30th, ’22, 20:09
Can you please be more specific? Example?
FastKeys Text Expander works with multiple keyboard layouts. Could you try reloading FastKeys after changing the layout?
Krasnij
Post by Krasnij » Jan 30th, ’22, 21:39
I using 2 layouts: russian and english. For example. I bind triple K pushing on english layout for text: "Dear user, unfortunately, this book has not yet been published, and has not been voiced." I`m working on blind typing and dont watch what layout (russian or english) I`m using right now.
Starting typing triple K, which on russian is another letter, nothing works. The problem is solved by binding same text for this button on russian layout . As a result, for one text I need to make two rules. I dont know how works my previous utility punto switcher, but in here I wrote one rule for kkk, and it sends text no matter on russian or english layout I`m standing. In punto switcher this option calls, "changing text, if you wrote on another language layout".
