The content not visible when expanding window editor
nhatfx95
Post by nhatfx95 » Nov 15th, ’21, 03:55
After drag a edge for a window to expand, I can't see the content fully. How to fix it ??
nhatfx95
Post by nhatfx95 » Nov 15th, ’21, 04:31
The OK and Cancel button is not shown at bottom of the window
Post by Tom » Nov 15th, ’21, 21:45
Strange. Could you try resizing the window to max or min size and than close it?
nhatfx95
Post by nhatfx95 » Nov 16th, ’21, 12:19
Tom wrote: Nov 15th, ’21, 21:45 Strange. Could you try resizing the window to max or min size and than close it?
Yes, I did as you said and got this problem. I don't know how to get back to normal. I try to restart the app, computer but it still not fixed
Post by Tom » Nov 17th, ’21, 06:49
Could you try resetting the Preferences to defaults?
nhatfx95
Post by nhatfx95 » Nov 17th, ’21, 07:42
Tom wrote: Nov 17th, ’21, 06:49 Could you try resetting the Preferences to defaults?
Yes, but still not work. Anyway I reinstall the software and it back to normal.
