Good night!!
I bought the FastKeys program today (11/05/2021). After making the payment, I downloaded the free program. So far I haven't been able to open it, when I click on the program's icon, it doesn't open (running).
I tried to delete the program to reinstall it, but the following message appears:
"Uninstall has detected that FastKeys is currently running. Please close all instances of it now, then click ok to continue, or cancel to exit"
I await the return of the process.
faskeys doesn't running in my PC
To open the FastKeys main window, press F8 or click on the FastKeys Tray icon. Tray icon is a small icon on the very bottom right of the screen. If the icon is missing, click the triangle icon in the task tray and drag the FastKeys icon into the system tray to make it permanently visible.
See more information here: https://fastkeysautomation.com/document ... Guide.html
To uninstall you first need to exit FastKeys. Right click on a FastKeys Tray icon and select exit.
