Column Headers With Sorting
thepipe
Post by thepipe » Aug 20th, ’21, 18:59
May we please have column headers that allow users to sort by clicking the column name? Including a caret indicator to show the direction of sort with this functionality would he helpful. Being able to sort can help users easily find specific items. See attached image. Thanks.
Post by Marko » Aug 20th, ’21, 21:59
You can right-click on the list and select Sort.
thepipe
Post by thepipe » Aug 21st, ’21, 01:23
Thanks very much for the reply. Yes, I realize that, but that only offers the option of sorting by String or Description. Users are unable to sort by items that are enabled/disabled or by type. It's also significantly less convenient as it requires multiple steps, as opposed to a single click. Is there any chance the this function will be expanded/redesigned? Thanks for your consideration.
Post by Marko » Aug 21st, ’21, 13:49
Thanks. We will put it on the wish list for possible future implementation.
thepipe
Post by thepipe » Aug 21st, ’21, 17:14
