not seem to work on Surface Pro X (Windows ARM)
moxou
Post by moxou » Jul 4th, ’21, 00:28
Hello
I've just install Fastkeys on my surface pro X.
It don't seem to work (nothing happend after lauching the App - No error, no result, no GUI)
Guillaume
Post by Marko » Jul 4th, ’21, 20:22
I'm not sure Windows ARM is compatible with the Windows desktop applications.
You could try running FastKeys in a safe mode to see if this helps.
