Pop up Screen
vincentt
Post by vincentt » May 21st, ’21, 03:25
Hi Fastkeyer,
This is the BEST text expander software I ever use. I like the auto complete and text expander and they can share the variables.
One more thing, I wish can have a pop up screen (something like iframe) instead of direct to the browser.
Cheers...
Post by Marko » May 21st, ’21, 13:30
Thanks for your kind words!
Sorry, I'm not sure what you mean by iframe pop up screen.
vincentt
Post by vincentt » May 21st, ’21, 16:01
The idea generation from this as reference.
For example, I copy the word and trigger the pop screen (such as website) then paste the word.
Or run "www.website.com/query-keyword" then pop up the landing page.
Cheers.
Post by Marko » May 21st, ’21, 17:43
Check various scripts in the Library, for example, Search Wikipedia, Search Text in Word Dictionary etc.
vincentt
Post by vincentt » May 22nd, ’21, 09:19
hi marko,
I have tried to search the sample but unable to find the relevant solution.
Do you mind sharing a sample for me?
Cheers.
Post by Marko » May 22nd, ’21, 09:37
Select a Library button to open the Library and then search for mentioned scripts.
