Input Selection Form scroll-bar
hpenner
Post by hpenner » Feb 16th, ’16, 16:44
First i want to appologize for my englisch. I´m not very good at it.
I´ve got the problem, that i created a text expander with a lot of selections and inputs. There are serveral CheckBox Lists, ListBoxs and Text inputs. My problem is, when i try to run the TextExpander the Input Selection Form-popup is that large, that it is not shown completly. Same thing with the "OK" and "Cancel" button. There is no way i can find to scroll-bar. Is there a possiability to create a scroll-bar or an other way to show the selections.
I atteched two pictures, the first one how it looks like the last one is from a window with a higher resolution, so that the form is shown completly.
Many thanks in advance, and please if you response try to keep the answer simple because i'm a beginner with fastkeys and as i said my englisch is realy not that good.
Greets from Germany
Post by Marko » Feb 16th, ’16, 19:20
Thanks for your valid suggestion, I agree this can be the issue with smaller screens.
For better visibility I suggest you simply split it into two parts.
hpenner
Post by hpenner » Feb 17th, ’16, 09:42
Thanks a lot for the quick answer!
Just found the INSERT funktion. It is working now. Not perferct but its running.
Have a nice day
Post by Marko » Feb 17th, ’16, 14:26
Why don't you use two SELECT macros instead of one?
