Shortcut icons problem
FastQuiz
Post by FastQuiz » Feb 15th, ’21, 01:04
Version 5 onwards application shortcut icons are not displayed.
Post by Marko » Feb 15th, ’21, 20:39
Try using a Open icon to select a shortcut from disk. Does it work?
FastQuiz
Post by FastQuiz » Feb 16th, ’21, 00:50
When I select the shortcut, the original location of the file is selected.
C:\Users\User1\Desktop\AIMP.lnk ---> C:\Users\User1\Desktop\AIMP460\AIMP.exe
In version 4 it works properly with the following settings.
v5 doesn't have type Open?
Post by Marko » Feb 17th, ’21, 21:20
This was simplified in 5.0. Run type now covers Run, Open and Script type commands.
We'll try to improve the icon display in the next update, thanks!
