Settings.fdb
averebazmadar
Post by averebazmadar » Feb 12th, ’21, 15:57
Hi!
I downloaded the portable version but in the settings's Folder section there is no option to change "settings.db" location. Therefore if I copy FastKeys folder to another location I get an error because it try to load it from the older one.
I can change the location in the .ini file but I think it shouldn't have been that way, right?
Post by Tom » Feb 12th, ’21, 16:44
You can run your fdb file from any location. Use File/Save as... and File/Open to load it.
Location of the settings.ini file cannot be changed.
averebazmadar
Post by averebazmadar » Feb 13th, ’21, 08:00
Oh I see thanks
