Disable Clipboard Manager
TokyoMike
Post by TokyoMike » Jan 12th, ’21, 01:43
Hi - I have set the history to 0 and clicked "delete" to display "none" as the shortcut - after exit and save the shortcut comes back.
I would like a method to completely disable this function as it interferes with another function in another app. For now, I have just set it to a different keymap and added Visual Studio Code to the Not Active In section.
Post by Marko » Jan 12th, ’21, 11:41
After changing the Preferences, click OK and the shortcut should not "come back". Also, setting the history to 0 completely disables the Clipboard Manager.
