How to select input option when list is large
sanchitgoyal
Post by sanchitgoyal » Nov 21st, ’20, 11:58
Hello
http://prntscr.com/vnc3ob
When there are lots of values how can We select the desired option? There doesnt seem to be a scroll bar. Thanks.
Post by Marko » Nov 21st, ’20, 12:58
Use a Drop Down List.
sanchitgoyal
Post by sanchitgoyal » Nov 21st, ’20, 13:35
Any plans of adding a scroll bar in this list?
Post by Marko » Nov 21st, ’20, 19:52
The scroll bar should appear when the list is larger than screen height. You may need to restart FastKeys after changing the monitor setup.
sanchitgoyal
Post by sanchitgoyal » Nov 23rd, ’20, 11:53
It doesn seem to be appearing.
http://prntscr.com/vod8ly
Post by Marko » Nov 23rd, ’20, 12:21
It works on our setups. Are you using multiple monitors? Could you check your Preferences/Appearance/Input Selection Form? Please contact our support mail for further support.
