Cannot pause on 4.2.3 with ctrl 2
JGM22
Post by JGM22 » Dec 4th, ’19, 14:27
Just upgraded to 4.2.3 and when I press ctrl 2 it does unpause but when I press ctrl 2 to pause it will not work. I need to hover over the icon in the system tray, right click and select pause. I changed the shortcut to ctrl 3 and it does unpause/pause. I switched it back to ctrl 2 and same issue, unpause works but pause does not.
Post by Marko » Dec 4th, ’19, 18:30
Thanks, I see. We will resolve this in the next release. Until then you can change the Pause shortcut to something else, for example Ctrl + F2.
JGM22
Post by JGM22 » Dec 9th, ’19, 14:43
Thank you, much appreciated as always...JGM
gbotes
Post by gbotes » Dec 12th, ’19, 14:46
I have the same issue. No hotkey combination I've tried with 2 in it as an alternative has worked. I have temporarily reinstalled version 4.22.
Post by Marko » Dec 12th, ’19, 17:41
There should be no difference between 4.22 and 4.24.
