Common Words Misspelled
KneeOnLite
Post by KneeOnLite » Sep 21st, ’19, 21:28
Hi I just bought Fastkeys and I'm getting to know it, previously I used a program called Breevy, I have used it for quite a few years and liked it a lot. Unfortunately it looks like its not being updated anymore.
One of the best functions of Breevy which I will miss, is the automatic correction of commonly misspelled words. As an example if I typed "afew" Breevy would automatically correct it to "a few". This is a huge help if you type quickly and hit the wrong key, as I often do. There is no user input it just replaced the misspelled word.
It (woyld this would have been auto corrected in Breevy)be great if you could add this function to Fastkey, I have the file with all the misspelled words and the correct words if you would like it.
Post by Marko » Sep 22nd, ’19, 15:40
This is one of the main features of FastKeys. :D
Just enable "Auto Correct English" phrase file (Text Expander/Phrase files).
