Two commands for same action?
Admirer
Post by Admirer » Aug 19th, ’19, 05:34
Under the preset defaults of library, I found two commands assigned to ''double tap esc key - 1. minimize the window 2. close the window
Can anyone explain this?
Actually, when I tried to verify, only no. 2 (closing the window) operates. :roll:
Post by Marko » Aug 19th, ’19, 19:32
Library entries may not work in some Windows versions.
Admirer
Post by Admirer » Aug 20th, ’19, 00:47
I use windows 10.
But can two different commands attributed to the same action of a key? In such case, Which one will be selected first?
Post by Marko » Aug 21st, ’19, 20:29
Yes, you can set different commands to the same key if you specify different target Window for each.
