type command
stevenwi87
Post by stevenwi87 » Aug 8th, ’19, 09:05
Its possible Using command script and send Manual Form??
https://imgur.com/CGjWrLa
Post by Tom » Aug 8th, ’19, 23:07
What would you like to do?
stevenwi87
Post by stevenwi87 » Aug 11th, ’19, 08:43
i want combine command script with send macros >Manual text Input (Variable Name) its possible sir??
Post by Marko » Aug 12th, ’19, 07:43
One way would be to use Insert Command Code macro:
Type: Send
Command:
%INPUT__Entry%%CODE_MyCode%
In the code you can than use the variable:
Msgbox %INPUT__Entry%
I used No Output' prefix "_" in front of a variable name (_Entry) to instruct FastKeys not to output the value.
