How to use a recorded macro in a task?
Steve Clark
Post by Steve Clark » Aug 7th, ’19, 13:38
I cannot seem to figure out how to insert a recorded macro into another task. I've looked at
the documentation and maybe I missed it.
Thanks
Steve
edit: I should have said,a saved recorded macro.
Post by Marko » Aug 7th, ’19, 14:39
Create a new item by using Insert/Recorded macro... menu.
Then you con reuse from another phrase using Insert Another Item macro (More/Macros...)
