Auto complete wordlist: possible write "#word" to trigger but Fastkeys inserting "word" (without #)?
Post by Marko » May 19th, ’19, 17:09
I understand your point Carlos. At the same time we need to make sure that we do not clutter the interface with very specific features which could confuse other "regular" users. If in your case # or $ may be a prefix of a real tag words, why can't you choose other prefixes, like , . % & etc.?
cadudesun
Post by cadudesun » May 24th, ’19, 23:47
Hi Marko,
Further reflexion:
=> I was taking literally the use of just three prefixes (# _ $), but from your last answer I realized you are going to let the user free for choose any prefixes (# _ $ , . % & etc), right?
This indeed increases the flexibility for handling my usage scenarios.
=> Although the usage of any prefixes (# _ $ , . % & etc) would increase the flexibility of the functionality, and I would be glad just with this improvement :) I do believe that FastKeys delivering a prefix control per list will fit any "power" user case, for the present and future time. At same time I do understand your concern regarding cluttering the interface for "regular" users.
A suggestion to make all the world happy: In the wordlist global options you have in mind, create a single option (e.g. a checkbox) like "allow override of global options per each wordlist". Just when the user check this option the controls per each wordlist would appear:
You will realize in the prototype, along with the prefixes field, I'm also suggesting that you allow override of the "word length to show suggestion". I would the global setting in 3 words, but I would love to have very special lists popping up with 1 or 2 word length!
I think other options are irrelevant for customization per each wordlist. Just overriding of "prefixes" and "word length" would be enough to reach the sky of flexibility and power!!!
Thank you very much.
Post by Marko » May 26th, ’19, 07:43
Thanks Carlos, good ideas. We will proceed with the global option first which is relatively easy to implement. Other solutions are more complex and would require some changes of how FastKeys currently operates - I will put it on the wish-list and see if such changes are feasible.
cadudesun
Post by cadudesun » May 26th, ’19, 14:48
Marvelous!
You are a great and responsive developer Marko!
Thanks for the forthcoming implementation.
I'm glad FastKeys is part of my "swiss army software".
Best,
Carlos
cadudesun
Post by cadudesun » Jun 3rd, ’19, 12:10
Hi Marko,
Many thanks for the implementation of the functionality in v4.19!
Tested and working marvelously!
For reflexion, maybe a complement to the functionality name could make its usage clearer:
- Prefixes removal
- Prefixes (removal when auto-completing)
- Prefixes to be removed
etc.
Best regards,
Carlos
