suggestion on using %INPUT_name% once but getting 2 different-formatted outputs?
RMDoubleYou
Post by RMDoubleYou » Apr 11th, ’19, 10:53
Hello.
I'm currently in a java software development traineeship and now quite often i need to write a 'getter' and a 'setter'.
The IDE (IntelliJ) can do this automatically but if its not necessary i'd rather not get the mouse and do some clicks (yeah i am very lazy -_-).
My idea was to have a text expander with the following content:
public %INPUT_type% get%INPUT_name%{(}{)} {{}
return this.%INPUT_name%{;}
Now lets say for %INPUT_name%, i enter "counter" than the output will be
public int getcounter() {
   return this.counter;
(IntelliJ adds the 'tab' and the closing bracket very nicely)
But i want to have Fastkeys type the following
public int getCounter() {     --> notice the capital letter C here, that's the difference
    return this.counter;                   --> but no capital letter C here. I've been taught that this is convention and i'd like to follow this convention.
Now i could get the following convention by asking for the name twice (%INPUT_name1% and %INPUT_name2%) but this can typo's.
Is it possible to only have one %INPUT_name%, but tell Fastkeys to type it once WITH a capital letter and once WITHOUT a capital letter?
Thanks for your help in advance,
With kind regards,
-RMDoubleYou
Post by Tom » Apr 11th, ’19, 11:23
One way to handle this is by using a small script in Insert Command Code macro:
Command (Type: Send)
%INPUT__Type%%INPUT__Name%%CODE_script%
CODE_script:
Send, public %INPUT__type% get%INPUT__name%{(}{)} {{}
StringUpper, INPUT__name, INPUT__name, T
Send, {Enter}return this.%INPUT__name%{;}
Note that I used 'No Output' prefix "_" in front of a variable name to instruct FastKeys not to output the value.
RMDoubleYou
Post by RMDoubleYou » Apr 12th, ’19, 09:15
Hello Tom,
Thanks for the answer, It seems to be doing what i want.
except for where the capital letter is printed is precisely reversed.
When i now 'call' this text expansion as you have described it i get the following:
A popup with:
"_type" ---> boolean (what i enter)
"_name" ---> taken
(so far so good)
and output is
public boolean gettaken() {
return this.Taken;		---> where i GET the capital letter now
But i would like:
public boolean getTaken() {	---> where i WANT the capital letter.
return this.taken;
I'll play around a bit and see if i can get it myself,
But i'd be gratefull if you could help me again.
With kind regards,
RMDoubleYou
RMDoubleYou
Post by RMDoubleYou » Apr 12th, ’19, 09:26
Hello again,
I managed to get it to work as how i want it by changing the Command Macro to the following:
StringUpper, INPUT__nameUpper, INPUT__name, T
Send, public %INPUT__type% get%INPUT__nameUpper%{(}{)} {{}
Thanks again for the help! :D
RMDoubleYou
