How to use "Window to left or right Half of the Screen" with multi monitor
angang
Post by angang » Mar 23rd, ’19, 20:41
How to use "Window to left or right Half of the Screen" with multi monitor ?
The command always put half right or left on monitor 1 also when the window is in the monitor 2.
Also, is it possible to not have the margin between windows ?
Thank you
Post by Tom » Mar 23rd, ’19, 22:00
You can simply use the following Windows shortcuts (Type: Command) instead:
Send, #{Left}
;and
Send, #{Right}
angang
Post by angang » Mar 24th, ’19, 01:16
It works like a charm, thank you so much Tom !
