vrod5454
Post
by vrod5454 » Mar 21st, ’19, 20:46
Is there a way to insert another item of type send within a type command? I am creating an email from a shortcut.
TYPE COMMAND
Run, "C:\Program Files (x86)\Microsoft Office\root\Office16\OUTLOOK.EXE" /c ipm.note
Sleep 1000
Send, {tab 2}This is my subject line{tab}%INSERT_EmailBody%
%INSERT_EmailBody% has text that I use reuse.
Thanks.
Post
by Marko » Mar 22nd, ’19, 22:44
You can insert another Text Expander item within the script by using a Gosub command and abbreviation string:
