Text to one line macro
Oblomov
Post by Oblomov » Mar 4th, ’19, 19:58
Does anyone know how one would go about pasting (clipboard) text into one line as in:
https://lingojam.com/TexttoOneLine
I've tried following example of this thread:
https://autohotkey.com/board/topic/9338 ... pied-text/
but to no avail
Post by Marko » Mar 4th, ’19, 21:19
Try this:
String:=clipboard
StringReplace, string, string, `n, , A
StringReplace, string, string, `r, , A
Send, % string
Oblomov
Post by Oblomov » Mar 4th, ’19, 21:30
Marko wrote: Mar 4th, ’19, 21:19 Try this:
String:=clipboard
Send, % string
That did it. Many thanks.
Oblomov
Post by Oblomov » Mar 4th, ’19, 22:09
String:=clipboard
Send, % string
By the way, note sure if I ought to make a thread on it's own for this, but you wouldn't perhaps also know of a macro that pastes back copied text, all in small letters?
Post by Marko » Mar 5th, ’19, 17:33
Similar to above..
String:=Clipboard
StringLower, string, string
Send, % string
Oblomov
Post by Oblomov » Mar 5th, ’19, 17:39
Marko wrote: Mar 5th, ’19, 17:33 Similar to above..
String:=Clipboard
Send, % string
Much obliged! Would upvote if I could
