Call a FastKey Shortcut from a batch file or command line
vrod5454
Post by vrod5454 » Feb 5th, ’19, 15:52
Is it possible to call a FastKeys text expander or shortcut from a windows command line/batch file?
Something similar to
"C:\Program Files (x86)\FastKeys Portable\FASTKEYS.EXE" /select SOME-TEXT_EXPANDER-OR-SHORTCUT-STRING
*note: the above path is just an example
Thanks.
Post by Marko » Feb 5th, ’19, 22:55
This is not possible. However, you can run any command(s) automatically when FastKeys starts - create Start Menu item(s) and select "Run on startup" option.
