Modify url - Chrome
gpapig
Post by gpapig » Jan 14th, ’19, 15:04
Hi Everybody,
Is it a way to find the current URL, to erase all parameters (like aaa=asdsad?bbb=test) and to replace them by my argument? If possible under chrome
Example
from
https://aaa.bbbb.net/aaa/order?Type=test&key=XXXX
to
https://aaa.bbbb.net/aaa/order?form
May be my question is stupid/eady, but i've tried by reaching the url bar with shortcut (alt + d) and the copy and edit the current url, but even just the first part, reaching URL, did'nt work.
Thank you for your answer and have a nice day
Gpapig
Post by Marko » Jan 14th, ’19, 18:48
This example selects the url, copies it to clipboard, removes the characters right from "?", adds "form" and sends it back.
Send, !d
Send, ^c
Sleep 200
Text:=Clipboard
SendInput, % SubStr(Text, 1, InStr(Text, "?")) "form"
gpapig
Post by gpapig » Jan 21st, ’19, 12:42
Hi Marko !
Thank you it works perfectly!
