hi,
i want a simple keyremapping.
Left alt key => left control key
i am a beginner user, so if someone helps me easily i really appreciate.
Thanks.
simple remap keys
Not that obvious. Create any dummy shortcut (which will not be used) with following:
Type: Command
Command:
Type: Command
Command:
LAlt::LCtrl
