Passing an argument to a program
Andyj
Post by Andyj » Dec 17th, ’18, 23:55
Hi, I'm a new Fastkeys user and I'm trying to set up my start menu. I've created a number of menu items to start my favorite programs (using the run command) but some of these require an argument to do what I want. Normally I could type
"program.exe /argument1" but I cannot figure out how to do this in the start menu. Any help would be appreciated! Thanks.
Post by Marko » Dec 18th, ’18, 12:53
It should work the same as usual. In some specific cases you may try to enclose string is quotes:
Type: Run
"program.exe /argument"
program.exe "/argument"
or Type: Command
run, "program.exe /argument"
run, program.exe "/argument"
Andyj
Post by Andyj » Dec 19th, ’18, 04:03
Thanks Marko! One of your options works for me. Much appreciated. Another question if you don't mind - can I run a command with admin privileges? And if so, how do I do this? Thanks again, Andrew
Post by Marko » Dec 20th, ’18, 08:15
Try (Type: Command)
Run *RunAs program.exe
More information:
https://autohotkey.com/docs/commands/Run.htm
Andyj
Post by Andyj » Dec 21st, ’18, 13:55
Thanks Marko! Fixed my problem and I'm now reading the reference guide...
