Generate New Outlook email with ticketing info added
wbr4@mac.com
Post by wbr4@mac.com » Nov 7th, ’18, 21:54
Hi FastKeys,
How do create a script or automation that takes ticketing information from a web page
(Name, ticket number, Issue summary) and then opens up Outlook 365,
creates a new email, then drops the gathered info in the
composed body of the email.
Currently I have this... see attached
but how to do you create the actions of opening Outlook and dropping the data
in the body
William IV
Post by Marko » Nov 8th, ’18, 19:15
Here is a simple way to open a default mail program and paste the text into the body:
%CODE_OpenMail%{Tab}{Tab}{Tab}Good Morning %INPUT_FirstName%,
Thank you for contacting us.
Create CODE_OpenMail by selecting the "Insert Command Code" macro with the following script:
Run mailto:
Sleep 1000
Dependent on your system you may need to adjust the number of tabs ({Tab}) and delay (increase Sleep).
wbr4@mac.com
Post by wbr4@mac.com » Nov 19th, ’18, 21:46
Thank you Marko, Ill try this out and work on this...
