Hello
In the example TextExpander entries for ame there is a line: %SELECT_RandomQuotes%
Where are the RandomQuotes that this example draws on located?
RandomQuotes for examples
Double-click on a macro field %SELECT_RandomQuotes% to open a macro dialog.
https://www.fastkeysautomation.com/docu ... acros.html
https://www.fastkeysautomation.com/docu ... nForm.html
Oh my - so simple - thank you. I have been using your product in a very limited way up until now and I have only just started to uncover the awesomeness!Marko wrote: ↑Oct 11th, ’18, 07:47 Double-click on a macro field %SELECT_RandomQuotes% to open a macro dialog.
Mike
