Autocorrect and paste in Gmail letter
dixam
Post by dixam » Aug 7th, ’18, 08:54
Hi, all!
Thanks for such useful app.
As a novice in it (don`t kick) there are two questions:
1. Autocorrect option. How to did it? I mean two ways: if I type dont` it must correct to don`t after Space button press (for example) and one more - change keyboard: I type водка it correct to vodka after I press some hotkey. Does this app can do this?
2. I tried rtm example in Text Expander/Default but it doesn`t work in my case. I copied two texts paragraphs from Word file (just text) and want to paste this text as a answer in Gmail letter. How can I do it with fastkeys?
Thanks for your assistance! Be cool.
Post by Marko » Aug 7th, ’18, 21:19
Hi and welcome to FastKeys.
1. You can create autocorrect items in Text Expander module - Auto Correct English file is already available - you can enable it in Phrase Files tab. You can also add your own items.
2. To create a rich text snippet, right-click on the Substitute field and select Rich-text from a context menu. You can then write the text or copy it from another application (Word etc.)
