Start with unchecked checkboxes
Loxtus
Post by Loxtus » Jul 25th, ’18, 10:06
Hi again,
another basic question:
Is it possible to configure checkboxes in %Select%-Functions, that they start with an unchecked checkbox?
Greetings Loxtus
Post by Marko » Jul 25th, ’18, 22:01
Checkboxes in selections are unchecked by default.
Loxtus
Post by Loxtus » Jul 26th, ’18, 08:12
That does not work for me. Every checkbox in every textexpanding is always checked on by default.
Post by Marko » Jul 27th, ’18, 18:09
Ok, the first checkbox is active by default. Should this be changed to none?
Looking forward to opinions...
Loxtus
Post by Loxtus » Jul 31st, ’18, 06:14
My vote would go to unchecked by default :mrgreen:
Or maybe even the possibility to decide for myself for each case.
kiyiya
Post by kiyiya » Aug 13th, ’18, 04:34
I agree with Loxtus. I would like to decide the status of a check box or radio button myself. If I uncheck it in the Preview I would like it to stay unchecked when ran. For example: I ask for a phone number and the input is that it is a Cellular number (from a Radio Button list). I then ask if a text message is ok. I would not like the type of number or the text message ok to be selected by default.
Thanks
