Error While adding or editing any item in Start Menu
Vivek
Post by Vivek » Jul 17th, ’18, 14:05
Hi folks,
I am getting an error
" This parameter contains a variable name missing its ending percentage sign"
while adding or editing an item in the Start Menu of fastkeys. I have tried uninstalling and reinstalling. I have tried each command while adding namely open, run etc. without any luck. No matter whatever I do I am getting this error each time I try to edit fastkeys' start menu.
Can you help me solve this, please?
Thanks
Vivek.
Post by Marko » Jul 17th, ’18, 15:49
Can you edit one of the example items? Please open the provided example file - File/Open - Examples. Does it work?
To be able to review your settings please contact us on support at fastkeysautomation.com. Please attach your Settings.fdb and Settings.ini files.
Vivek
Post by Vivek » Jul 18th, ’18, 10:40
I cannot edit the example file as well. I am confused as the first time when I installed it, it was working fine so that can't be related to system access or antivirus interrupting the software.
I have emailed you the details along with the Settings.fdb and Settings.ini files.
Your help will be highly appreciated.
Thank You.
