Create command
david
Post by david » Jun 14th, ’18, 00:38
I am trying to make a command that inputs end, space, delete and then wait for 150ms so that I can repeat and give a small time in between.
I tried this command:
Send {End}
Send {Space}
Send {Del}
Sleep 150
But it throws an error saying
Error at line 16.
Line Text: %
Error: This parameter contains a variable name missing its ending percent sign.
The program will exit.
Can you kindly help me see what is missing?
Thanks a lot for the help! :)
Post by Marko » Jun 14th, ’18, 06:45
It should work. This is even simpler:
Type: Send
{End}{Space}{Del}{150}
