can not open folders/files
kavusha
Post by kavusha » Jun 3rd, ’18, 08:18
Hi everybody,
i am very new to Fast Keys - so have mercy on me
Can somebody tell me why i am not able to open any files or folders with the shortcuts i've created.
In the attachment there is a screenshot of one of my shortcut command window.
I appreciate any help.
Kavi
Post by Tom » Jun 3rd, ’18, 09:15
Hi Kavi and welcome to the forum.
The easiest is to click on Open button and then select the file/folder. Your link to the image is not working, you can post your command.
kavusha
Post by kavusha » Jun 3rd, ’18, 12:13
Hi Tom,
thank you for a quick reply!
Yes, i tried both - used the "open" button and typed the folder's address manually. Neither worked.
Here is the contents of one of my command window
Shortcut Str + L
Type open
Command D:\Users\Kavi\Desktop\Tuning
And how do i insert an image to my post?
Kavi.
Post by Tom » Jun 3rd, ’18, 12:30
Try another shortcut and try another folder to see what's the problem. Try also provided examples in Start menu - do they work?
kavusha
Post by kavusha » Jun 3rd, ’18, 13:26
The examples in the startmenu work all right.
I've tried quite a few combinations with different keys and different folders. None work so far.
Post by Tom » Jun 4th, ’18, 13:34
Can you try
Shortcut: Alt + X
Command: C:\Program Files
kavusha
Post by kavusha » Jun 4th, ’18, 14:11
I've tried that. No luck.
I also tried and switched to different keyboard layouts. No luck here as well.
Post by Tom » Jun 4th, ’18, 16:36
Try reloading FastKeys after changing the language.
kavusha
Post by kavusha » Jun 4th, ’18, 19:17
Still nothing.
Post by Tom » Jun 4th, ’18, 19:58
So none of the example shortcuts work?
Please send your settings.fdb file to our support mail and I will check.
