Shift+Enter
david
Post by david » May 29th, ’18, 00:44
Hello!
I wanted to ask a very simple question. I am trying to do a script that types: backspace and shift+enter. I can't seem to do a shift+enter, only enter. Can you please help me on this one?
Thanks a lot!
Best regards,
David.
Post by Marko » May 29th, ’18, 09:59
This should work:
+{Enter}
david
Post by david » Jun 1st, ’18, 00:15
Thanks a lot!
I want for this simple script to do:
Backspace
Backspace
Shift+Enter
Shift+Enter
This is how I have it: http://share.epiclemon.com/rzYy
Unfortunately it acts weird, and most of the times it is like having two full enters. I believe maybe it is too fast for the program to register such fast sequences? I was trying to add a sleep time, with command type, but could not. Can you please help me out?
Thanks so much for the help :)
Post by Marko » Jun 1st, ’18, 12:44
{Backspace}{Backspace}+{Enter}+{Enter}
